PSing.5
Jul 9, 2021 4:43 PM UTC
How to choose CAN driver?
I enabled CAN 2 in low level drivers, chose the correct pins under pinout but I get error (undeclared variable) when I try to can_lld_start(&CAND2, &can_config_cfg0);
How do I use a specific CAN bus in code and how do I enable it? Do I type &CAND5 for the fifth bus?
    PChia.2237
    Senior
    Jul 12, 2021 6:36 AM UTC
    I think you mean
    #include "adc_lld_cfg.h"
    see RLA CAN Test Application for Discovery
    PSing.5
    PSing.5Author
    Jul 14, 2021 8:48 PM UTC
    I included #include "can_lld_cfg.h" for the CAN drivers but I am trying to figure out why I can not use other CAN channels. I enabled them using the software under low level drivers and assigned pins in the pinmap editor.
