PLEE.2
Feb 9, 2023 4:26 PM UTC
how to add a version information in image?
hello.
how to put the defined version information(32bit value) in the built image (test.hex or test.bin)?
    Javier1
    Javier1Best answer
    Principal
    Feb 10, 2023 2:02 PM UTC
    I use prebuild scripts that includes some github information from the repository.
    https://community.st.com/s/question/0D53W00000q6pT7SAI/stm32cubeide-how-to-add-a-custom-pre-post-scripts
    You could do something similar with a 32 bit variable
    hit me up in https://www.linkedin.com/in/javiermuñoz/
    Javier1
    Javier1Best answer
    Principal
    PLEE.2
    PLEE.2Author
    Feb 13, 2023 7:42 AM UTC
    thanks. javier
    It's been a lot of help.
    by the way, i use spc5studio..There is no menu that corresponds to the above.
    I'm searching hard in my own way.
    I want to say thank you again.​
    Javier1
    Principal
    Feb 13, 2023 8:29 AM UTC
    I never used spc5studio, i cannot help you there
    Erwan YVIN
    Feb 13, 2023 3:19 PM UTC
    Hello PLEE ,
    the solution provided by Javier is ok.
    you should create your own include file version.
    with static const char* VERSION = "myversion"
    Best Regards
    Erwan
