Yali Mobilities
Aug 9, 2021 7:11 AM UTC
how could i use version controller (git) with spc5studio.
while i am pushing my project into repository, the application configuration is missing from the project. so how could i properly use a version controller with spc5studio.
    Erwan YVIN
    Erwan YVINBest answer
    Aug 12, 2021 12:05 PM UTC
    Hello ,
    SPC5Studio is based on eclipse
    you can install git for eclipse by using this update site :
    Git integration for eclipse
    EGit P2 Repository - https://download.eclipse.org/egit/updates
    Best regards
    Erwan
    Erwan YVIN
    Hello ,
    Best regards
    Erwan
    Jan 10, 2024 11:06 AM UTC
    Tried installing the git for eclipse as given in the previous post but the installation is failing. It is showing
    "The installation cannot be completed as requested".
    Attaching the screenshots here.
    Could anyone please help with this?
    Aug 15, 2024 8:00 AM UTC
    Facing the same issue. Were you able to find any solution ?
    Aug 15, 2024 8:10 AM UTC
    The issue is, the latest EGit is not compatible with SPC5 Studio. Hence we need to install the older version of EGit.
    Go the archives and select one of the older version to enable EGit.
    Archives Website: https://archive.eclipse.org/egit/
    I have installed https://archive.eclipse.org/egit/updates-5.10/ and it works fine.
    Aug 15, 2024 12:58 PM UTC
    @asn, thank you very much for your reply.
    I got the EGit installed now.
    But couldn't see any options for version control enabled in SPC5Studio. If its working for you, could you please share how you get it working and configured the repository.
    Aug 16, 2024 8:00 AM UTC
    Once it is installed, Go to Window -> Perspective -> Open Perspective -> Other and in the pop window select Git. Now you will be able to see the Git Tab in the top right corner.
    Hope this helps.
    Erwan YVIN
    Aug 20, 2024 12:35 PM UTC
    In fact , SPC5Studio is using an old version of eclipse
    you should use a version compliant with SPC5Studio one.
                              Best Regards
                                                  erwan
