GJord.3
Mar 28, 2023 12:08 PM UTC
How compile old project of SPC58?
Good morning,
I am a technician who works for a company. I have to manage different projects related to the SPC58ECxx. My problems are that I can modify the bootloader or the application but if I use the configurator and re-compile they stop working. I think it's a low-level library generation issue. I tried to use different ide like SPC5Studio6.0.0-Green and SPC5Studio6.0.0-Asimov but nothing different. How can I keep the projects compatible with the ide I use? Thanks to the availability
    Erwan YVIN
    Mar 30, 2023 1:37 PM UTC
    Hello ,
    could you give me the version used for your Application ?
    i can give you the version for your application.
    i will send the right lld version with SPC5Studio
    Best Regards
    Erwan
    GJord.3
    GJord.3Author
    Mar 31, 2023 7:33 AM UTC
    Hi, where is the application version?
    Aniway I managed to fix it. I saw that the application was missing some configurations concerning the adc. Perhaps the former colleague saved it badly on the server. it is possible that .gitignore at these addresses: .build, .dep, .settings can cause problems?
