Rajesh kumar
Mar 9, 2017 7:14 AM UTC
Hi i am working on Project with a SPC560D40 an SPC5 Studio. I'm trying to generate PWM-Signals on the Pins RA0 to RA5. When I look in the eMIOs Settings of the SPC560Dxx HAL Driver Component, I can only activate eMIOs group 0 (Channel 9..15) or Group
Posted on March 09, 2017 at 08:14
hello i am working on Project with a SPC560D40 an SPC5 Studio. I'm trying to generate PWM-Signals on the Pins RA0 to RA5. When I look in the eMIOs Settings of the SPC560Dxx HAL Driver Component, I can only activate eMIOs group 0 (Channel 9..15) or Group1 (Channels 17..23) but RA0 to RA5 should be Channel 0..5. For these Channels I can only activate ICU drivers.
    Erwan YVIN
    Erwan YVINBest answer
    Mar 9, 2017 9:44 AM UTC
    Posted on March 09, 2017 at 10:44
    Hello Rajesh ,
    yes , it is our HAL Drivers implementation.
    you can use patch mode to update our HAL drivers
    icu_lld.c or pwm_lld.c directly in SPC5Studio.
    or contribute in
    https://github.com/microwan/spc5-hal
                                 Best Regards
                                                Erwan
    Erwan YVIN
    Hello Rajesh ,
    or contribute in
                                 Best Regards
                                                Erwan
