BKuma.3
May 25, 2021 9:51 AM UTC
Hi, how to get pin mapping of SPC584C70E3. Please help.
    zambrano.luigi
    zambrano.luigiBest answer
    May 26, 2021 9:36 AM UTC
    HI Bipin,
    it is not possible to identify the device from the topmarking. You can refer to the content of the registers MCU ID Register #1 (SIUL2_MIDR1) and MCU ID Register #2 (SIUL2_MIDR2) for the details about the device.
    Regards,
    Luigi
    zambrano.luigi
    May 26, 2021 8:23 AM UTC
    if you download the PDF file TN1260 - SPC584Cx, SPC58ECx IO definition: signal description and input multiplexing tables from this link, you can find in attachment a couple of files xlsx containing all the information needed for the pin configurations of your device.
    Regards,
    Luigi
    BKuma.3
    BKuma.3Author
    May 26, 2021 8:52 AM UTC
    Dear Luigi,
    This attachment is not found in the pdf file. Can you please help on this.
    cannot able to locate the paper clip symbol as per the instruction on the document.
    Bipin.
    zambrano.luigi
    May 26, 2021 8:57 AM UTC
    Hi Bipin,
    please, see the following picture
    Regards,
    Luigi
    BKuma.3
    BKuma.3Author
    May 26, 2021 9:10 AM UTC
    Dear Luigi,
    Thank you so much for the help. That was an issue with PDF Reader version.
    Further to it,
    IS it possible to identify the MFR part of SPC58 series MCU, from the topmarking of the IC ?
    Please help if you can get the MFR part of the IC topmarking : SPC58 VQ830325 2210J VQ MLT 22 918.
    Best Regards,
    Bipin
    zambrano.luigi
    HI Bipin,
    Regards,
    Luigi
    Vlad Mishustov
    Sep 10, 2021 8:43 AM UTC
    Hi, Luigi!
    Is it possible to identify SPC58 device without connecting to the registers?
    If I take device in my hand to solder it on a board, how can I be sure that it is right chip?
    BKuma.3
    BKuma.3Author
    May 26, 2021 10:31 AM UTC
    Dear Luigi,
    Thank You for the support.
    Regards,
    Bipin
    zambrano.luigi
    Sep 10, 2021 10:07 AM UTC
    sorry, but I'm not able to identify the device from the topmarking that you shared. Please, check this link to more information about the product of the SPC8 family.
    Regards,
    Luigi
