DRA
Jun 23, 2020 6:17 PM UTC
hello, I have a ST92F150 microcontroller, is there a tool for recording and reading it so that it comes out more into account
microcontroller ST92F150
    Jun 23, 2020 7:26 PM UTC
    You mean like STVP9 ?
    Not sure it can recover protected devices.
    DRA
    DRAAuthor
    Jun 23, 2020 7:31 PM UTC
    o que seria STVP9, um programador ou software?
    Jun 23, 2020 7:37 PM UTC
    Programming software I'd presume
    https://community.st.com/s/question/0D50X00009XkhAtSAJ/trying-to-find-st9-visual-programmer-for-epb
    This is probably the wrong place for cracking / chipping support
    DRA
    DRAAuthor
    Jun 23, 2020 7:49 PM UTC
    e qual hardware devo usar para ler e programar o microcontrolador?
    Jun 23, 2020 9:37 PM UTC
    A programming method is described in the data sheet as I recall, you could implement that on a platform of your choosing.
    Not sure it facilitates a read-back method, you would presumably need a .BIN or .HEX of the firmware you've generated
    20 year old stuff, not really much commercial interest at this point. ST used to have an EPROM Programming Board (ST92F120-EPB) you should check with your local sales office. I suspect at this point you'll need to buy or construct your own gear.
    http://www.microcontroller-cafe.com.ua/products/automotive/st92f_isp
    Programming App Note.
    https://www.st.com/resource/en/application_note/cd00004275-st9-flash-programming-stmicroelectronics.pdf
