vinithramarapu
Aug 1, 2024 10:24 AM UTC
Frequent Debugging/Flashing Errors with SPC574S64E3 MCU using iSystem Bluebox iC5700
Dear STMicroelectronics Community,
I hope this message finds you well.
We are currently working on a Battery Management System (BMS) project using the EVAL-L9963E evaluation board, which incorporates the SPC574S64E3 microcontroller. For debugging and flashing our code onto the MCU, we are utilizing the iSystem Bluebox iC5700 along with the winIDEA platform.
However, we have encountered a recurring issue during the debugging and flashing process. The error we consistently face is shown in the attached image. Each time this error occurs, we are compelled to reset and restart the entire hardware setup, which raises our concern about potential long-term hardware failure due to frequent resets.
We are seeking your expertise to understand how we can prevent this error and mitigate the need for repeated hardware resets. Your assistance in resolving this issue would be greatly appreciated, as it is crucial for the smooth progression of our project.
Thank you for your attention and support.
Best regards,
Vinith Ramarapu.
