guo qiang
Senior
Nov 17, 2017 3:34 AM UTC
FreeRTOS port on the SPC, I think there is a problem
Posted on November 17, 2017 at 04:34
If the kernel need to switch task in the SystemTick(PIT0)ISR,  this should be to trigger a SystemCall.
STM32 PORT:
the vTaskSwitchContext function only made some judgments, to modify pxCurrentTCB, and did not do the task switch.
Yvin.Erwan.001
null
    guo qiang
    guo qiangBest answer
    Senior
    Nov 17, 2017 3:39 AM UTC
    Posted on November 17, 2017 at 04:39
    I modified the code:
    But I found that there is no task will not switch
    guo qiang
    guo qiangAuthorBest answer
    Senior
    Erwan YVIN
    Nov 17, 2017 8:26 AM UTC
    Posted on November 17, 2017 at 09:26
    Hello Guo ,
    I am submitting an ER on FreeRTOS components part.
    Thank you for sharing your findings ;)
       Best Regards
                 Erwan
