Aug 31, 2019 9:03 PM UTC
flexcanstcomm
- 4 replies
- 2687 views
Hi Dears
First (if its important):
I want to program for 560b50 and it isn't in platform list. list started with 54. what should I do?
Secondly :
I configure "enable filters" in flexcan visual configuration from respective component and so generate ...
but defined "SPC5_CAN_USE_FILTERS" have "False" value in all respective codes (cfg , header , lib).
using spc560b CAN example , was the similar result and this defined , have "False"!
I tried another family chip and everything was right. ("SPC5_CAN_USE_FILTERS" changed with visual configuration.)
Do you think there is a problem?
have I become sensitive?
