PChia.2237
Senior
Jul 26, 2021 7:47 AM UTC
Firmware Updater SPC560BC Family
Hi i have a custom board with SPC560B50L3 that is in the  SPC560BC Family.
There is no SPC560BC xx Firmware Updater Component.
If i try to add it (with shw incompatible components) of course i have problem generation files.
There is some alternative?
    PChia.2237
    PChia.2237Best answer
    Senior
    Jul 28, 2021 6:24 AM UTC
    OK, i copy all files and folders and component.mak from SPC560B xx Firmware Updater Component and it works!
    PChia.2237
    PChia.2237AuthorBest answer
    Senior
    Erwan YVIN
    Sep 17, 2021 8:15 AM UTC
    Normally ,
    if the component is incompatible , generation is failing , it is normal
    could you check Firmware Updater test application ?
    Best Regards
    Erwan
