YLin.2
Nov 12, 2020 4:18 PM UTC
Filter and Mask configuration of FlexCAN for SPC560
I can't find any document that defines the Filter and Mask for FlexCAN, so I post a question about it.
I think the filter only passes frames that contain exact ID as the ID in ID mask field. Am I right?
0693W000005BDKVQA4.jpgBest regards
Yuechuan Lin
    DCARR
    Mar 21, 2022 11:18 AM UTC
    YES you are right.
    The CAN controller is configured to use the RX global mask that is set to 0x0FFFFFFF
    Best regards
    Domenico
    PChia.2237
    Senior
    Dec 7, 2022 8:54 AM UTC
    Is possible to change or just check this RX global mask?
    Because i have a problem in standard RX that seams that filter mask is not 0x7FF , but 0x3FF.
    I have tested in this way:
    RX ID= 0x1
    up to message id 0x201 -> 0b 0010 0000 0001 filter works
    if i send message id 0x401 ->0b 0100 0000 0001 filter not works, because i i receive the message.
    Best Regards,
    Patrick
    PChia.2237
    Senior
    Dec 7, 2022 9:40 AM UTC
    I have solved replacing in can_lld.h
    canp->flexcan->RXGMASK.R = 0x0FFFFFFFU;
    with
    canp->flexcan->RXGMASK.R = 0xFFFFFFFFU;
