Daniele Mirri
Mar 21, 2017 4:07 PM UTC
Error in the test application??? SPC5Studio
Posted on March 21, 2017 at 17:07
I'm using the test application 'STM test Application for discovery'  and also if i never used it, when i want to compile it i have this 3 errors:
FMPLL-IN has a value (0) out of range: [4000000,64000000] configuration.xml /SPC560Bxx_RLA STM Test Application for Discovery FMPLL-IN Problem
FMPLL-VCO has a value (0) out of range: [256000000,512000000] configuration.xml /SPC560Bxx_RLA STM Test Application for Discovery FMPLL-VCO Problem
XOSC has a value (0) out of range: [4000000,16000000] configuration.xml /SPC560Bxx_RLA STM Test Application for Discovery XOSC Problem
Can someone help me??
Does someone knows where are those variables and which are the correct values??
Many thanks.
    Erwan YVIN
    Erwan YVINBest answer
    Mar 22, 2017 9:35 AM UTC
    Posted on March 22, 2017 at 10:35
    Hello Daniele ,
    You have chnaged the default settings.
    You can use SPC560Bxx Clocktree in the test application to check your clockpoint.
    anyway, please refer to the RM for the permitted value. (Cf Clock Chapter)
      Best regards
                     Erwan
    Erwan YVIN
    Hello Daniele ,
      Best regards
                     Erwan
