NBula.1
Enabling lockstep core in SPC570S MCU
I am prototyping on a SPC570S-DISP development board, and I am trying to enable the checker core in the MCU. I read the technical reference manual, and it has stated that the checker core can be enabled from the UTEST DCF memory registers. How can I access these registers from the SPC5 application, because such a setting is not available in the configuration GUI. Furthermore, I would really appreciate if I could get some advice as to how to access other registers as well.
Thank you.
Nisal
    Erwan YVIN
    Erwan YVINBest answer
    Hello ,
    you can not access by GUI Settings
    you need to access by adding some constants
    /*UTEST DCF pattern */
    #define UTEST_DCF_records 	0x00400308 /* just after DCF_start_Record */
    #define UTEST_DCF_PASS_ADDR 0x00400308 /* DCF START */
    you can try to access after locking UTEST Address Space
     /* Lock to Protect UTest Address Space */
     test_string_print(&SD1, "Lock UTEST Address Space: ");
     returnCode = GetLock(&ssdConfig, C55_BLOCK_UTEST, &blkLockState);
     if (C55_OK != returnCode)
     ErrorTrap(returnCode);
     if (!(blkLockState & 0x00000001))
     returnCode = SetLock(&ssdConfig, C55_BLOCK_UTEST, LOCK_ALL_BLOCKS);
     test_string_print(&SD1, "OK!\n\r");
    Example in Flash Test Application
    Best Regards
    Erwan
    Mannhof
    Hi all! I'm also trying to change UTEST DCF in SPC570S40 (but I want to change XOSC LF_EN bit value).
    In RM0349 on the page 260 I see it's Reset value. How can I read it? UTEST Flash memory with the same address is empty.
    If I'm flashing address 0x00400308 but nothing changes. How can I check current values which stored in this memory?
    Thank you,
    Nikolay Mannhof.
    Erwan YVIN
    Hello ,
    Best Regards
    Erwan
