May 6, 2026 9:29 AM UTC
DEBUG IDE TOOLS FOR SPC582B
For SPC582B, which development IDE is recommeded for code debug and run? Does PLS JTAG debugger software ok to run some demo when using SPC582B-DIS discovery board?
KTANG.9
May 21, 2026 5:34 AM UTC
We have a SPC5 Studio IDE / AutoDevKit IDE - https://www.st.com/en/embedded-software/stsw-autodevkit.html
Many Sample project
Has graphical pinmap editor to configure the MCU pins.
SPC582B-DIS has built in UDE Debugger on board. You can install PLS UDE Software to connect directly to board.
There is a UDE folder in each sample project which you can use to open a debug.wsx workspace in PLS UDE Software after you compile the project.
Best Regards
Kong Choy
Best Regards
Kong Choy
