Parth1
Mar 3, 2021 6:31 AM UTC
Debug first project in SPC5 Studio
Hello
I am new to SPC5 Studio, please guide me how I can debug my first project.
I am working with SPC5 Studio ver 6.0.0. and have SPC56D_DISCOVERY Eval board.
    Erwan YVIN
    Erwan YVINBest answer
    Mar 3, 2021 10:24 AM UTC
    Hello ,
    Integrated PLS Debugger (UDE) is a 32 bits product.
    it is not compliant anymore with SPC5Studio 6.0.
    a change request has been submitted in PLS company
    you should use PLS UDE Tools as as external use.
    https://community.st.com/s/question/0D53W00000JjNVCSA3/unable-to-install-pls-ude
    Best regards
    Erwan
    zambrano.luigi
    Mar 3, 2021 6:49 AM UTC
    please, refer to the help integrated within the tool (Help -> Help Contents). There are specific sections dedicated to SPC5Studio.
    Regards,
    Luigi
    Parth1
    Parth1Author
    Mar 3, 2021 7:52 AM UTC
    Hi
    Thanks,
    I have gone through the help content and faced following issues:
    • License error:
    • Error with using PLS integrated debug option:
    • I have externally used UDE STK window to debug the project and following error is observed while programming.
    kindly let me know, where I am wrong.
    zambrano.luigi
    Mar 3, 2021 8:11 AM UTC
    which UDE STK script do you have selected to connect to the target? Could you try to load the script available in the UDE folder (spc560d_discovery_debug_jtag.cfg) within the test application folder?
    Regards,
    Luigi
    Parth1
    Parth1Author
    Mar 3, 2021 9:40 AM UTC
    Hi
    using "Debug.wsx" file in UDE folder of the project.
    Thanks for your help, I am able to debug now.
    Also, please let me know how to use integrated PLS debugger from the software. Now I am externally using it and opening my configuration file in it.
    Following is the attached snip of installing integrated PLS debugger
    Thank you
    Erwan YVIN
    Hello ,
    Best regards
    Erwan
