SMELL.1
May 29, 2023 2:05 PM UTC
Current consumption of SPC584Cx in Max run mode
I work with this component and i want to estimate the maximum current consumption,
in the other MCU there is section how talk about maximum current consumption in run mode or I can simulate with cubeMX but with this MPU I don't found this parameter, can you help me as soon as possible please
what is the worst case current consumption of SPC584Cx ?
Olivier GALLIEN
May 29, 2023 2:12 PM UTC
Hi @SMELL.1​ ,
SPC5 is not part of STM32 family and so do not benefit of same ecosystem.
redirect your post to relevant community in order you get relevant support
In the meantime I find this resource on st.com that may help
AN3316.book (st.com)
SPC5 32-bit Automotive MCUs - PDF Documentation (st.com)
Olivier
Giuseppe DI-GIORE
Jul 12, 2023 6:03 AM UTC
download the device datasheet [link] and see the section "Device consumption", several use cases with relative consumption are described in such section.
Best regards.
