Yalin Gurcan
Jun 28, 2018 9:20 AM UTC
Cross compiling for SPC570Sx without SPC5Studio
Posted on June 28, 2018 at 11:20
I'd like to cross-compile code without using SPC5Studio for
SPC570S5E1 on a linux box, which version of gcc would I need and what flags should I use? Do I need a special toolchain for the e200z0 core?
Thanks in advance
#gcc #cross-compilation
    Erwan YVIN
    Erwan YVINBest answer
    Sep 23, 2022 9:21 AM UTC
    Hello ,
    You can find the linux freegcc here :
    http://spc5tools.spc5studio.com/tools/freegcc/plugins/
    Best Regards
    Erwan
    Erwan YVIN
    Jun 28, 2018 2:44 PM UTC
    Posted on June 28, 2018 at 16:44
    Hello Yalin ,
    you can find the freegcc for powerpc vle (linux) in the following directory (cf plugins)
    http://spc5.drive.cloudforge.com/projects/spc5tools/updates/
    Compilation is OK
    for your information we have a SPC5Studio Linux beta version
      Best regards
                Erwan
    pslav.1
    Apr 4, 2023 10:51 PM UTC
    Hi, I'm looking for some tool for compile SPC58 on a linux box, no mother if GUI or CLI or java based commands. Something to get out of windows Have you some tool for that. Thanks.
    GCole.1
    Sep 23, 2022 9:04 AM UTC
    I have the same problems in order to cross-compile in Linux base environment the SPC570S5E1 with command line, but the suggest source is not longer available.
    Can i find the fregcc?
    Thanks.
    Best regards,
    Gianni
    Erwan YVIN
    Hello ,
    Best Regards
    Erwan
    GCole.1
    Sep 23, 2022 12:37 PM UTC
    Thank you Erwan.
    Also, is there any st document designed to support command line development in unix environment?
    Best regards.
    Gianni
