NDinu.1
Oct 19, 2020 2:50 PM UTC
Creating a new SPC5 application from Scratch
I am using a SPC570S-DISP development board, and I am trying to create a new application form that. I have tested out a few example application given in the IDE, and they work fine.
Now I want to develop such an application from scratch. However, there seem to be no guide as such, showing the necessary step to follow in order to properly configure the application. I have also referred the Help section.
One problem that I came across is that, in the MCU wizard, I am unable to configure any of the peripherals. When I click on one of the peripherals, no options seem to appear. Is there a document that can be referred, or a tutorial that I can follow?
Thanks.
Dinuke
    Erwan YVIN
    Erwan YVINBest answer
    Oct 21, 2020 9:30 AM UTC
    1) First, add the platform component
    2) You have to click on the + button to add the compatible component
    Best regards
    Erwan
    Erwan YVIN
    Oct 20, 2020 2:54 PM UTC
    Hello Dinuke ,
    There is a help section in SPC5Studio , (Cf Help Section)
    you can add any compatible component, configure and generate the code.
    Best Regards
    Erwan
    NDinu.1
    NDinu.1Author
    Oct 20, 2020 4:16 PM UTC
    Hello Erwan,
    I followed the help section. I have already created a new SPC5Studion application. I cant unable to find compatible components. Where do I can find the compatible components.
    Best Regards,
    Dinuke
    Erwan YVIN
    Best regards
    Erwan
