Nluke.1
Mar 29, 2021 1:52 AM UTC
could you show me the memory map of the device SPC584B60E3, what is the exact size of this divice?
 I have the memory map on page 76 of this manual,
https://www.st.com/resource/en/reference_manual/dm00400546-spc584bx-32bit-mcu-family-built-on-the-power-architecture-for-automotive-body-electronics-applications-stmicroelectronics.pdf
but it is for 2M flash memory, for my device it is 1M, i have read out the  MCU ID Register #2(SIUL2_MIDR2), one value is 0Xb0004200(1M), but actually i found the flash all be programmed correctly to 2M.
    Nluke.1
    Nluke.1Best answer
    Apr 2, 2021 1:09 AM UTC
    Hi Luigi,
    thanks, this is helpful.
    thanks a lot
    Luke
    Mar 29, 2021 9:51 AM UTC
    Parts using the same die, but only portion of it tested.​
    Nluke.1
    Nluke.1Author
    Mar 30, 2021 6:40 AM UTC
    Hi DeLorean,
    thanks for your reply. so do you know for the 1M flash chip, whether the address from 0x010C0000 to 0x011BFFFF should not be included. thanks a lot.0693W000008yF0rQAE.png
    zambrano.luigi
    Mar 31, 2021 9:56 AM UTC
    the SPC584B60 has a flash size of 1MB. You can find the details within the related Datasheet at this link, at pag.129 Table 73.
    Regards,
    Luigi
    Nluke.1
    Nluke.1AuthorBest answer
    Hi Luigi,
    thanks a lot
    Luke
