Breizh_Instruments
Jun 18, 2021 9:29 AM UTC
Compatibility of UDE MemTool with SPC5-UDESTK programmer
I want to use the automation features of the UDE MemTools with a SPC5-UDESTK programmer, as it is said in this article, but it seams that there is a licence missmatch. Is there a specific license to have in order to use it?
Thank you by advance.
    Erwan YVIN
    Erwan YVINBest answer
    Jun 18, 2021 12:48 PM UTC
    Hello Breish ,
    Yes , you can use SPC5-UDESTK programme in CI Automation bench.
    https://www.st.com/resource/en/data_brief/spc5-pls.pdf
    About license,
    the StarterKit version , you are limited to 128k
    the registered version unlocks the limitation of code size.
    Best Regards
    Erwan
    Erwan YVIN
    Hello Breish ,
    About license,
    Best Regards
    Erwan
    Breizh_Instruments
    Jun 18, 2021 1:04 PM UTC
    Hello Erwan,
    Thank for the answer, but as it is said is the picture, there is no Script support for the SPC5-UDESTK.0693W00000BbNYJQA3.jpg
