Harsh1
Jul 12, 2021 11:36 AM UTC
Code does not execute when the ADC was setup in "RTOS example" on SPC560P50L5 which comes with spc5 studio?
MCU - SPC560P50L5
First I compile and flash RTOS serial example with no errors. then I run it. No errors were detected. same process was followed to check ADC example. There also no error were found. Then I combined both codes as follows(attached). It compiled with no errors. But it did not run smoothly. The LEDS always lit.
    Erwan YVIN
    Erwan YVINBest answer
    Jan 19, 2022 2:48 PM UTC
    Hello ,
    Have you tried with the last version of SPC5Studio ?
    Warning: Component com.st.spc5.components.platform.spc560pxx_rla version (1.16.0) doesn't match installed component version (1.16.1)
    Version set to 1.16.1.
    Warning: Component com.st.spc5.components.init.spc560pxx_rla version (1.16.0) doesn't match installed component version (1.16.1)
    Warning: Component com.st.spc5.components.lld.spc560pxx_rla version (1.16.0) doesn't match installed component version (1.16.1)
    Warning: Property i2c_settings[1]/i2c_sw_configurations[1]/configs[1]/settings[1]/slave_address[1] was not found in configuration file.
    Additional things :
    Your pinmap does not contain ADC Settings.
    Best regards
    Erwan
    Erwan YVIN
    Hello ,
    Additional things :
    Best regards
    Erwan
