Hank Im
Jan 31, 2018 12:17 AM UTC
CFlash module example code for SPC560B60L7
Posted on January 31, 2018 at 01:17
Hello!
I'd like to use CFlash module without using C90LC Standard Software Driver(SSD).
But I don't konw how to configure it.
Could you provide me an example code?
i.e) CFlash initialize, CFlash Erase, CFlash Write, etc...
Thank you.
    Erwan YVIN
    Feb 1, 2018 10:28 AM UTC
    Posted on February 01, 2018 at 11:28
    Hello Hank ,
    Officially , we useC90LC Standard Software Driver(SSD)
    we have just an example for dflash coming from old posts
    Best regards
    Erwan
    ________________
    Attachments :
    spc5_dflash.c.zip : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006Hy4w&d=%2Fa%2F0X0000000b3i%2FBgicYvVwkEA8migGsDEqekerFan.EmEtJojyRPkYKBY&asPdf=false
    spc5_dflash.h.zip : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006Hy4r&d=%2Fa%2F0X0000000b3c%2FU89O0DvE0YbNG3HcmjYSfvh.XaG_3xPOV5RaeQ020n0&asPdf=false
    Hank Im
    Hank ImAuthor
    Feb 2, 2018 3:43 AM UTC
    Posted on February 02, 2018 at 03:43
    Hello, Erwan Y
    Thank you for your reply.
    But i already had the Dflash sample code. My Dflash sample code is the same as what you attached.
    I need a CFlash sample code.
    If the CFlash module configure is the same as the DFlash sample code,
    Should i change SPC5_DFLASH_BASE address to SPC5_CFLASH_BASE address in sample code?
    Thanks.
