Rassom
Nov 10, 2021 5:43 AM UTC
Cannot install SPC5-MCTK-LIB in SPC5Studio 6.0.0 (No repository found)
An error occurred while collecting items to be installed
session context was:(profile=DefaultProfile, phase=org.eclipse.equinox.internal.p2.engine.phases.Collect, operand=, action=).
No repository found containing: osgi.bundle,com.st.spc5.components.L9908.spc5xx_rla,1.0.0.202010121447
No repository found containing: osgi.bundle,com.st.spc5.components.l9907.spc56xx_rla,1.0.0.202010121447
No repository found containing: osgi.bundle,com.st.spc5.components.l99asc03.spc56xx_rla,1.0.0.202010121447
No repository found containing: osgi.bundle,com.st.spc5.components.motorcontrol.demos.spc56xx,1.0.0.202010121447
No repository found containing: osgi.bundle,com.st.spc5.components.motorcontrol.spc56xx,1.0.0.202010121447
No repository found containing: org.eclipse.update.feature,com.st.spc5.components.spc5rla.spc56xx.motorcontrol.feature,3.0.0.202010121447
No repository found containing: osgi.bundle,com.st.spc5.components.stgap1s.spc56xx_rla,1.0.0.202010121447
    Erwan YVIN
    Erwan YVINBest answer
    Nov 10, 2021 2:01 PM UTC
    Hello ,
    Which update site do you use to install SPC56xx Motor Control Feature ?
    No problem is noticed with
    https://www.st.com/content/my_st_com/en/products/embedded-software/mcu-mpu-embedded-software/spc5-embedded-software/spc5-software-tools-and-drivers/spc5-mctk-lib.license=1636552684621.product=SPC5-MCTK-LIB.version=3.0.0.html
    and http://mctkcust.spc5studio.com
    Best Regards
    Erwan
    Erwan YVIN
    Rassom
    RassomAuthor
    Nov 11, 2021 6:09 AM UTC
    Hello Erwan,
    Thanks for your reply. I was finally able to install 3.0.0.
    Initially, what I was doing was "Install New Software -> Add -> Archive" and then select the zipped folder en.MCTK_SPC5xxx_RTM_3_0_0_v3.0.0. This never worked ("couldn't find jar file" was the error message). Then, I unzipped the folder and selected content.jar file, and got the errors I posted above. Then, I tried "Install New Software -> Add -> Local" and selected the content.jar file and it worked.
    Cheers!
    Rassom
