guo qiang
Senior
Oct 17, 2017 9:56 AM UTC
Build Tools for SP5Studio
Posted on October 17, 2017 at 11:56
I would like to add some source files to the source folder. the files name are :clock.c   and so on.
but
build faild.
I know that this is a problem in the makefile, and SP5Studio provides  clock.c�?components.c .and My source files also have Clock.c and components.c...Causes the makefile rule to check for an error.
I think you should develop an eclipse plugin,like this:
In this case, the generated Makefile will not appear above the error
    Erwan YVIN
    Erwan YVINBest answer
    Oct 18, 2017 7:19 AM UTC
    Posted on October 18, 2017 at 09:19
    Hello ,
    on a SPC5Studio project , the Makefile is automatically generated (Freemarker)
    it is a good idea , we have created a change request for this.
                Best Regards
                               Erwan
    guo qiang
    guo qiangAuthor
    Senior
    Oct 18, 2017 12:35 AM UTC
    Posted on October 18, 2017 at 02:35
    carannante.procolo
    Yvin.Erwan
    simon.scullion
    bertrand.quesada
    Erwan YVIN
    Hello ,
                Best Regards
                               Erwan
    guo qiang
    guo qiangAuthor
    Senior
    Oct 18, 2017 10:29 AM UTC
    Posted on October 18, 2017 at 10:29
    I saw the eclipse has provided a seemingly similar plug-in, anyway, looking forward to the Build plugin ~
    Step 1:
    step 2:
    By the way, I am currently the RT-Thread RTOS ported to SPC5604B.
    https://github.com/RT-Thread/rt-thread
    ask a question
    Can I debug SPC5604 with PE debugger of MPC5604?
    Because the PLS debugger is too expensive.
    I have a PE debugger that probably costs $ 30
    Erwan YVIN
    Oct 18, 2017 10:45 AM UTC
    Posted on October 18, 2017 at 10:45
    Hello Guo ,
    No problem for this ,
    you can install it from
    https://www.pemicro.com/blog/index.cfm?post_id=124
     by update site mecanism . The link is on the blog
    Choose e200 target and create your de
    Install is OK
    It is not fully tested on our side. We have not PEMicro debugger.
    i think that it should work if you create your appropriate debug configurations
          Best regards
                         Erwan
