Fabio Malatesta
Oct 10, 2017 2:26 PM UTC
ADC conversion is not stable
Posted on October 10, 2017 at 16:26
Hello!
I'm using XPC56xL minimodule on the XPC56XX motherboard.
I slightly modified the SPC56ELxx OS-Less ADC Test Application to print the ADC conversion values on the UART
The issue I noticed is that the value of the conversion is not stable: for example if I print 15 measures (all of them done without changing the trimmer position) I get the following result (in hexadecimal):
ADC Value:
278
279
274
278
277
274
272
272
275
278
276
274
276
276
278
276
So it seems that the 4 least significant bits are given only by the noise. Since i read on the reference manual that the ADC has 12 bits resolution, i would like to know if there is a strategy to keep those bits stable.
Thank you in advance!
kind regards,
Fabio
    Erwan YVIN
    Erwan YVINBest answer
    Oct 13, 2017 10:28 AM UTC
    Posted on October 13, 2017 at 10:28
    Hello Fabio ,
    I have checked with ADC Experts on 12 bits conversion
    the results below are good.
    ADC Value: (4095 max)
    278
    279
    274
    278
    277
    274
    272
    272
    275
    278
    276
    274
    276
    276
    278
    276
        Best Regards
           Erwan
    Erwan YVIN
    Oct 11, 2017 6:55 AM UTC
    Posted on October 11, 2017 at 08:55
    Hello Fabio ,
    For a normal conversion , you have to increase PSAMP it is more stable.
    Could you increase it ?
    Sorry, The RM is not accurate for this point.
           Best regards
                           Erwan
    Fabio Malatesta
    Oct 11, 2017 4:18 PM UTC
    Posted on October 11, 2017 at 16:18
    Hello Erwan,
    Thank you for your help but the situation hasn't changed: i tried several values for PSAMP (also the maximum) but those 4 LSB are still unstable.
    The value should be stable, because it simply depends on the value of the trimmer resistance.
    Do you have any further suggestion?
    Thank you in advance for your support!
    Kind regards,
    Fabio
    Erwan YVIN
    Oct 11, 2017 5:15 PM UTC
    Posted on October 11, 2017 at 17:15
    Hello Fabio ,
    I am checking with ADC experts.
             Best regards
                        Erwan
