Nov 1, 2025 8:40 AM UTC
SPC564L60L programer
Hi. I'm looking for a programmer for SPC564L60L5. The best would seem SPC5-UDESTK but it is not available for sale. Or maybe StellarLINK It will be ok for full programming and debugging support for this chip. Or maybe some other suggestions of a programmer who would support SPC564L60L5?
Thank you for your help
Best regards Christopher
SRomeo
SRomeoBest answer
Nov 17, 2025 10:12 AM UTC
Hi there,
Actually, you do not need the license hightec to run AutoDevKit or flash your boards.
But ,if you want to remove the annoying hightec message, take a look to this thread.
Regarding PLSUDE, (our legacy flashing method) you can find some resources here.
We recommend switching to OpenOCD technology, using our new AEK-MCU-SPC5LNK (here you can find the drivers)
Anyway,
If you are looking for support to reverse engine or fix an existing ECU, I'm sorry but you should contact the manufacturer.
Best regards,
Simone
AEK_Team
Max VIZZINI
Nov 1, 2025 5:49 PM UTC
You can use AEK-MCU-SPC5LNKU, it is equivalent and available on e-stores.
Best Regards,
AutoDevKit Team
Nov 2, 2025 8:43 AM UTC
Thank you for your reply. It has already been ordered. And if it turns out that the chip has a password, is there any way to decrypt it?
Max VIZZINI
Nov 2, 2025 6:16 PM UTC
If you are talking about the FTDI chip on the programmer, I confirm that there is no password.
The chip comes with pre-programmed license UDE from PLS. It is free up to 256KB of code to be downloaded.
Best Regards,
AutoDevKit Team
Nov 6, 2025 9:17 PM UTC
No, I'm talking about the chip  SPC564L60L who is in the airbag controllers That I would like to fix and  unlock it. Is it possible to decrypt the password to access epprom memory? Or flash etc?
SRomeo
Nov 7, 2025 8:04 AM UTC
Hi there,
No, it's not possible.
Best regards.
SRomeo
SRomeoBest answer
Hi there,
Anyway,
Best regards,
Simone
AEK_Team
Nov 18, 2025 6:35 AM UTC
Thank you for your Help
Best regards
Christopher
