Aug 28, 2024 6:03 AM UTC
i want to add delay into my code
hi community,
i my project. i am using PIT and it is working fine. before initialization of the drivers osalThreadDelayMilliseconds() is working fine. but after initialization of the low level drivers, osalThreadDelayMilliseconds() is blocked even though when i had used osalThreadGetMilliseconds() logic . even though it is not working (bolcking the code (PIT also)).
is there any alternatives. to add delay's without blocking PIT.
E shiva
Aug 28, 2024 10:29 AM UTC
Please could you share your code and your pheripheral configuration?
Are you initializing (low level driver initialization) other peripherals besides the pit in your project?
Have you enabled irqIsr ?
int main(void) {
     componentsInit();
     /* Enable Interrupts */
     irqIsrEnable();
Luca R.
