Dec 17, 2025 6:01 AM UTC
how to hit halt or pause when the code hang in debugging session using UDE startkit tool
I am currently developing with the SPC582Bxx controller using the UDE STK Starter Kit for debugging. During runtime, the Program Counter appears to be stuck in a loop, and I am unable to identify the exact location of the hang. Could you provide guidance on how to troubleshoot this? Additionally, if a UDE STK debugging guide is available, please share it.
Thank you.
SRomeo
SRomeoBest answer
Dec 17, 2025 8:21 AM UTC
Hi there,
PLS UDE is a third-party SW. You may find technical help from the PLS dedicated community
ST from his side released a manual, which describes how to move your first steps in ST micro debugging via UDESTK. If you are using UDE STK then I suggest taking a look to the following documentation:
UM1659 UDESTK (page 11 onward)
Best Regards,
Simone
AEK_Team
SRomeo
SRomeoBest answer
Hi there,
Best Regards,
Simone
AEK_Team
