Nov 6, 2025 11:54 AM UTC
Free GCC License Not Detected in AutoDevKit Studio
I am trying to use a HighTec Free GCC license with AutoDevKit Studio 2.6.1, but I cannot compile my project.
Setup:
  • OS: Windows
  • IDE: AutoDevKit Studio 2.6.1
  • License: Free GCC
  • Installed compiler: Only VLE compiler (ppc-vle-gcc.exe) is present; ppc-free-gcc.exe is missing
Problem:
  • AutoDevKit shows “No license for product (-1)”.
  • Project’s Toolchain Editor only lists the VLE compiler.
  • I am unable to add the Free GCC compiler manually because the executable is not in the installation.
Request:
  • Please provide instructions or a link to obtain the PowerPC Free GCC compiler (ppc-free-gcc.exe) compatible with my license.
  • Guidance on installing and configuring it in AutoDevKit Studio so the license is recognized.
Thank you.
Giuseppe DI-GIORE
Nov 6, 2025 2:12 PM UTC
please ask for evaluation license directly to Hightec.
1) Register first to get the activation key
Here the link to register: Request of Evaluation Key - HighTec EDV-Systeme GmbH
2) Get the license file from here
HighTec Registration Form
Regards.
Max VIZZINI
Nov 6, 2025 1:00 PM UTC
In AutoDevKit Studio we only work with free gcc compiler, therefore we cannot support on Hightec license.
Best Regards,
AutoDevKit Team
ASH2930TAuthor
Nov 6, 2025 1:15 PM UTC
That's what my question is: where would I find the license-free compiler in Autodevkit? If it only works with it, it should be there, but I couldn't find it. My license is also free type, whereas my Autodevit is unable to locate the free compiler.
Max VIZZINI
Nov 6, 2025 1:26 PM UTC
There is no license required.
Worst case you need to adjust the path to your gcc compiler inside Eclipse to find the compiler.
Nothing else.
Best Regards,
AutoDevKit Team
Giuseppe DI-GIORE
Regards.
