May 12, 2025 7:49 AM UTC
eval-l9963e-mcu GUI only monitoring 3 cells of my 4-cell battery
Hi, after i have downloaded the softare. I tried to monitoring a battery pack made up with 4 cells in series. When i open the GUI, only the first 3 cells are monitored the last one isn't monitored. Anyone have a solution or a schematic about the pin? Cause the gui guide says that the minimum configuration is cell 1,2,13 and 14.
Thank you so much
Max VIZZINI
Max VIZZINIBest answer
May 28, 2025 4:24 PM UTC
even if only 4 cells are monitored, you have to make sure that all voltage sensing and balancing pins of the IC are well connected or the voltage reading will not work in the proper way.
A getting started User Manual:
https://www.st.com/resource/en/user_manual/um3185-getting-started-with-autodevkit-battery-management-system-bms-evaluation-boards-stmicroelectronics.pdf
Please notice that the tool you are using is out of support.
Best Regards,
AutoDevKit Team
Max VIZZINI
Best Regards,
AutoDevKit Team
