Bwang.3
May 19, 2024 10:23 AM UTC
Error message while using AutoDevKitStudio-2.1 OpenOCD! Hope to be resolved!
I am programming SPC582Bxx-RLA WKPU Test Application for Discovery using the SPC582860E1 development board! But when downloading the program using OpenOCD steps, the following error message will appear! As shown in the following picture! And I also took a screenshot of my configuration settings. I hope everyone can help me analyze the solution! Thank you.
QQ图片20240519180728.pngQQ图片20240519180722.pngQQ图片20240519180716.pngQQ图片20240519180708.png
ATROI
ATROIBest answer
May 20, 2024 8:03 AM UTC
Hi Bwang,
to solve this error pls execute the steps below:
step1: go in C:\{installation folder}\openocd\drivers.
step2: run as administrator the file UNISTALL_UDESTK.bat
step3: run as administrator the file INSTALL_UDESTK.bat
Three times the following window will appear where you need to uncheck the checkbox and after press the Install button.
at this point try to run the debugger.
Thanks,
AutoDevKit Team
ATROI
ATROIBest answer
Hi Bwang,
Thanks,
AutoDevKit Team
