Max VIZZINI
Mar 9, 2024 7:37 PM UTC
Design Tip Hot Plug BMS board
Dear Members.
The current BMS board design has not taken in consideration all the recommendation for a Hot Plug capable design.
To make your system hot-plug resistant make sure to follow the recommendations below:
  • Change the battery connector with a hot plug capable one
  • AGND and DGND grounds shall be connected to the internal node (i.e. GND of the chip) through the drain of the MHOT FET.
  • GND_ESD and PACK_GND  grounds shall be connected to the negative terminal of the battery pack
  • All big capacitors on the VBAT line shall be tied to the GND_ESD ground.
Keep improving your designs! ;)
Best Regards,
AutoDevKit Team
