Apr 22, 2025 4:40 AM UTC
Debugger can't connect to AEK-MCU-SPC5LNK.
I have some problems while debugging in AutoDevKit.
I did find this error log about the problem:
Open On-Chip Debugger 0.12.0+dev-00318-g0e98d766e (2023-05-17-15:52)
Licensed under GNU GPL v2
For bug reports, read
http://openocd.org/doc/doxygen/bugs.html
adapter srst pulse_width: 100
Started by GNU MCU Eclipse
Info : Listening on port 6666 for tcl connections
Info : Listening on port 4444 for telnet connections
Info : clock speed 4000 kHz
Error: JTAG scan chain interrogation failed: all ones
Error: Check JTAG interface, timings, target power, etc.
Error: Trying to use configured scan chain anyway...
Error: spc58xc.tap: IR capture error; saw 0x3f not 0x01
Warn : Bypassing JTAG setup events due to errors
Error: no IDCODE present on device
Warn : target spc58xc.cpu examination failed
Info : starting gdb server for spc58xc.cpu on 3333
Info : Listening on port 3333 for gdb connections
Info : accepting 'gdb' connection on tcp/3333
Warn : Waiting OnCE to leave reset mode
Info : Target no left the reset mode.
Error executing event gdb-attach on target spc58xc.cpu:
TARGET: spc58xc.cpu - Not examined
Info : flash: 4096 kbytes @ 0x00fc0000
Error: Target not examined yet
Error: auto_probe failed
Error: Connect failed. Consider setting up a gdb-attach event for the target to prepare target for GDB connect, or use 'gdb_memory_map disable'.
Error: attempted 'gdb' connection rejected
Error in final launch sequence
Failed to execute MI command:
-target-select remote localhost:3333
Error message from debugger back end:
Remote communication error. Target disconnected.: No error.
Max VIZZINI
Max VIZZINIBest answer
May 20, 2025 4:55 PM UTC
which version of AutoDevKit Studio do you have installed?
Best Regards,
AutoDevKit Team
Max VIZZINI
Best Regards,
AutoDevKit Team
