May 13, 2024 1:57 PM UTC
Breakpoints are working only at core2
I am trying to debug a code that are running in core0 and core1. I inserted a breakpoint inside main_core0() and main_core1() infinite loop, but the debugger does not stop on breakpoints. In the core2 the debugger stops on breakpoint.
I am sure that those codes are running because the LEDs that should be blinking by those codes, they are blinking.
I am using a SPC58NH-DISP board and the new AEK-MCU-SPC5LNK dongle configured to OpenOCD protocol.
Max VIZZINI
Max VIZZINIBest answer
May 14, 2024 10:27 AM UTC
You can debug only one core per time, not in parallel.
Best Regards,
AutoDevKit Team
Max VIZZINI
Best Regards,
AutoDevKit Team
