jsmit.1
June 28, 2022
What is the dual supplie condition for TS393 comparator?
I have q question about TS393 comparator.
Datasheet says :
Wide single supply range 2.7 V to 16 V or dual supplies (±1.35 V to ±8 V)
I dont understand dual supplies condition.What does mean "dual supplies (±1.35 V to ±8 V)"?
    Peter BENSCH
    Peter BENSCHBest answer
    Welcome, @jsmit.1​, to the community!
    The TS393 has two pins for the power supply: VCC- (pin 4) and Vcc+ (pin 8), but no pin for GND. The voltage difference between these two pins may be between Vmax=2.7-16V, whereby it doesn't matter whether you connect
    • VCC- to GND and VCC+ to this voltage, i.e. Vmax (this is also called unipolar), or
    • whether you work symmetrically to GND, i.e. VCC-= -Vmax/2 and VCC+=+Vmax/2 (bipolar).
    You can only process signals that lie in the respective voltage range, i.e. approx. 0...Vmax for unipolar supply and -Vmax/2...+Vmax/2 for bipolar supply.
    Does it answer your question?
    /Peter
    Peter BENSCH
    /Peter
