Alejandro Bizzotto_36523
TSV711 macromodel
In the datasheet for the TSV711 is sated (p20):
4.8 Macromodel Accurate macromodels of the TSV71x devices are available on the STMicroelectronics’ website at www.st.com.
So, where are they??? I looked everywhere, Digikey has a deadlink to the macromodel for the TSV71x. Why that document was removed?
    Peter BENSCH
    Hi, Alejandro,
    did you also check the product website under the tab CAD Resources?
    There you will find the TSV711 Pspice model.
    Good luck!
    /Peter
