Andrew Lohmann_2
TSV711/2/4 op-amp output resistor for stabilty
Posted on January 16, 2017 at 09:55
What is the lowest value of series resistor that I can use to maintain stability of this amplifier.
I would like to use a series resistor of 200R to 1K to a load that will have some variable capacitance. I need to use a low power op-amp, if you chose to suggest another..
#op-amp-stability
Anthony BOIMOND
Anthony BOIMONDBest answer
Posted on January 19, 2017 at 18:17
Hello Andrew,
As you probably have seen, the TSV711 is tested with acceptable stability performance with pure capacitive load up to 200pF (this is illustrated in Figure 13, p13/29 of the datasheet).
For higher capacitive loads, a series resistor can be used, as you suggested.
The chart here below shows recommended values of series resistor to ensure stability for a given capacitor value.
Hope it can answer to your question.
Best regards,
Anthony
Anthony BOIMOND
Hello Andrew,
Best regards,
Anthony
Andrew Lohmann_2
Posted on January 19, 2017 at 19:12
Thanks Anthony,
The op-amp is usable in my circuit with either 4K or 1K + 100nF. Your answer is approximately what I expected.
