LCE
Principal III
February 23, 2024
> 1. Is there a SPICE model available for this part?
It seems there's only the eDesignSuite link, I just tried it and that's quite useless, because TSV6392A can't be selected.
BUT the datasheet says something about a macro model...
> 2. Is the output open-drain or push-pull?
It's declared as an opamp, so that's usually push-pull.
Pierre SENNEQUIER
Hi Kay,
  Please find it attached.
As mentioned by LCE, yes this is a rail to rail op amp.
   Have a nice day,
Pierre
"In order to give better visibility on the answered topics, please click on ""Accept as Solution"" on the reply which solved your issue or answered your question."
