JDLR
January 19, 2023
TSC210 current leak path into VREF when IC has no VCC
There is a leak path between IN+ and VREF, through the feedback resistors when VREF is connected to GND.
I need to know whether this path is still possible when the IC has no VCC applied to it.
I disable the IC to save power consumption but if this path is still present in the absence of VCC, then I need to take other measures.
    Pierre SENNEQUIER
    Yes there is a pass even when the power is off.
    You can find it fig 17 of the datasheet. (https://www.st.com/resource/en/datasheet/tsc210.pdf)
    Best Regards,
    Pierre
    "In order to give better visibility on the answered topics, please click on ""Accept as Solution"" on the reply which solved your issue or answered your question."
