October 26, 2023
TSB582 consumption current error
Hello.
I would like to know about the error of TSB582 consumption current.
Please let me know if there is a figure between it's consumption current (or quiescent current) vs. supply voltage for the number of parts, and data on minimum and maximum consumption current.
Thanks.
Pierre SENNEQUIER
You may see a curve for one sample on the datasheet : https://www.st.com/resource/en/datasheet/tsb582.pdf (fig. 2)
If you need to size your application with the maximum value you should consider the values reported in the electrical characteristics of the datasheet.
Regards,
Pierre
"In order to give better visibility on the answered topics, please click on ""Accept as Solution"" on the reply which solved your issue or answered your question."
Pierre SENNEQUIER
Regards,
Pierre
