krdmitry
Simple audio recorder solution selection
Posted on December 03, 2015 at 10:51
Hi, All!
Could you please recommend audio amplifiers solution for mono recorder / player with following characteristics:
  • electret mic
  • dinamic speaker 0.3W
  • power voltage 3.0V
  • shutdown possibility is neccessary
  • not so expensive
  • will be used with STM32F3 12bit ADC & DAC for recording short voice tags to waypoints
Currently I'm looking for TS472 mic preamp and class-D or AB BTL speaker amp. Might is be a better solution?
BTW, is it possible to contol TS472 gain by MCU?  Or add a limiter?
Nickname1623_O
December 3, 2015
Posted on December 03, 2015 at 15:06
hi Dmitr,
TS472 gain setting can be controlled by MCU with different I/O .for more info you may check AN2240 in ST website. and for audio amplifier you can consider TS4871 .
thanks to consider ST device
YT
