luli755
Quiescent current definition
Posted on June 11, 2012 at 15:45
W
hat is the definition of quiescent current parameters in operational amplifier project?
Thanks,
Luli
#quiscent-current
Nickname14663_O
Posted on June 12, 2012 at 09:33
Hello Luli,
The quiscent current is equivalent to the ''supply current per channel'' as used in the op-amps product selector.
It represents the value of the current flowinginto the Vcc+ pin (positive supply pin).
Test conditions are: nominal voltagesupply, no load on output pin.
Regards,
Sylvain
