Pavel_47
Powering multiple optical front-ends
There are 8 optical front-ends on the board ... the front-ends based on TSV771 (or TSV772, TSV782, TSV791, TSV792).
Is it important to use one LDO per front-end or powering all 8 frontends by a single LDO will be also Ok ?
Thanks.
Peter BENSCH
Peter BENSCHBest answer
As I said, I don't know the circuit or the necessary parameters, but I assume that ferrite beads could be a bit scarce because their inductance is usually quite small. Perhaps a simulation or a test could be useful.
For the capacitors, MLCCs might be the best choice.
Peter BENSCH
Even if the opamps are used as transimpedance amplifiers, separate LDOs are not necessarily an advantage because their PSRR and its frequency dependence play a major role and should also be taken into account. Without knowing your application in detail, it might make sense in your case to use a single LDO and separate the supply voltages of the individual opamps cleanly with LC filters and a carefully designed layout including GND.
Hope that helps?
Good luck!
/Peter
Pavel_47
Pavel_47Author
Hi Peter
Thanks. Considering that the PSRR is quite high at low frequencies and damps at high frequencies, perhaps ferrite beads would be sufficient to separate the VDDs of OpAmps ?
Peter BENSCH
Pavel_47
Pavel_47Author
Ok, thanks Peter.
