allan
Offline opamps catalog ?
Posted on June 18, 2013 at 11:23
I'm product engineer and I'm regularly looking for op-amps on the your website.
Having a slow connection, I'm looking for a way to select op-amp being offline.
Do you have somthing to help me ?
Thanks,
Allan
#analog-audio-datasheets-download #op-amps
Anthony BOIMOND
Posted on June 19, 2013 at 17:14
Hello Allan,
You can try the attached file.
It's an extract of ST website product selector into an Excel file.
Additionallythis file can also download the datasheets to your local hard disk drive for later reading.
If you have internet connection available, we strongly recommend you to check for the information on-line: this is the place where information is up-to-date.
Best regards.
________________
Attachments :
AAS_Download_datasheets_2013.xlsm : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006Ht1A&d=%2Fa%2F0X0000000aIq%2FseP8bkeSDGOwTKlvyrNIt2m5NIu1p.pMSlC9ky4TjGE&asPdf=false
allan
allanAuthor
Posted on June 25, 2013 at 17:17
Thank you for the file, it does the requested job.
Allan
