ktomp.1
March 17, 2023
Is the TS954 SPICE model accurate
I matched figure 3 in the datasheet with a level3a spice model and I can get a good match. When I used your provided model the crossover is VERY low. Also I don't understant how the datasheet has 80dB of DC gain, but the model and open loop response look like 40 some odd DB.
Douglas MILLER
This forum thread was marked by the moderator as needing a little more investigation, so a Support case was created in your name and will be handled off-line. Should anyone have any similar questions, please feel free to open a Support case directly at your myST portal: https://st.com/ols
