DYann.1
Senior II
July 31, 2023
How to import a project ?
I found this link on the internet : https://github.com/logical/sgtl5000-stm42f4
But when i download and try to open it under STM32CubeIDE, I encounter errors such as this window.
Do you know how to convert to a correct format under STM32CubeIDE ? Thank you for your advice.
Regards.
DYann.1
DYann.1Author
Senior II
August 2, 2023
Here, you can find the project I don't know if it can open with STM32Cube IDE but I guess so. Thank you for your helps.
Pavel A.
August 2, 2023
The original project looks like for SW4STM32. Try to import is as SWSTM32.
DYann.1
DYann.1Author
Senior II
August 2, 2023
Import under STM32Cube IDE ?
I have nothing about SWSTM32, do I have to download dedicated software for this project ?
Pavel A.
August 2, 2023
Yes. In that menu, select "import acv6 System Workbench.... project"
DYann.1
DYann.1Author
Senior II
August 2, 2023
But, it's not complete, a lot of things are missing, for example the .ioc file
Probably I didn't do the right import method, I can't compile the project also.
Your RAR file doesn't include the whole project, just a few files. No chance of it working like that.
DYann.1
DYann.1Author
Senior II
August 2, 2023
Sorry, in this forum I can't send a ZIP file (which contains all the files) and I converted the ZIP file to RAR online. That why missing files.
I couldn't get it to work either. You can always create a new project for the appropriate chip then replace all the files with the ones in your project.
Pavel A.
August 2, 2023
Why won't you contact the author of the github project. He may be glad to help.
DYann.1
DYann.1Author
Senior II
August 21, 2023
HI,
I contacted but no response.
Pavel A.
August 21, 2023
Well, the author states in his GH profile that he suffers from a certain mental problem... There are other people that can and want to help you:  https://www.fiverr.com/categories/programming-tech/electronics-engineering/embedded-systems-iot
