0xfdrVisitor II5 years agoOctober 26, 2020Questionhow to configure sta510f output 4 independent channels, instead of 2 - Channel Bridge, thank you!0 replies466 viewsI now use sta311b+sta510f, how to configure sta510f output 4 independent channels, instead of 2 - Channel Bridge,Or how to make sta311b in each channel PWM output full PWM not half PWM, I can only get half the signal, bridge is not a problem TKS!
