TChri.3
Help identifying ST chip
I am trying to identify a chip with an ST marking. It is an SOIC-14 and appears to be identified with the markings 247. There are more markings on the package, but they vary from package to package and I suspect they are some sort of manufacturing and/or date code.
Based on the circuit the IC was found in I believe it's some sort of audio processor or transceiver.0693W00000aIr0nQAC.jpg0693W00000aIr0dQAC.jpg
    Peter BENSCH
    Peter BENSCHBest answer
    Welcome, @TChri.3​, to the community!
    It is the LF247DT, a quad JFET opamp.
    Does it answer your question?
    /Peter
    Peter BENSCH
    /Peter
    Explorer
    October 29, 2023
    Hi Peter, could you please explain how did you know the answer so that we can do it too? thanks.
    Peter BENSCH
    Well, this is knowledge that I have gathered over the past decades. I am happy to help with further questions of a similar nature, but I cannot guarantee it.
    TChri.3
    TChri.3Author
    Hi @Peter BENSCH​
    Yes, this is exactly the info we were looking for.
    Thanks!
    Peter BENSCH
    Great!
    If the problem is solved, please mark this thread as answered by selecting Select as best, as also explained here. This will help other users find that answer faster.
    /Peter
