DYann.1
Senior II
July 10, 2023
CS42L51-I2C
I have a evaluation board ST32L552E-EVAL, and I would like to know how it works the I2C with this component (for example to initialize the component. Do you know where can I find examples of this board with I2C communication ?
I can download an example name 'Demo' but I can't see the file '.ioc' about the clock configuration and also the other parameters to understand with this component.
Thank you for your helps
DYann.1
DYann.1Author
Senior II
July 10, 2023
After downloading 2 online examples SAI_AudioPlay and AUDIO_Standalone, I don't see communication by I2C in the '.ioc' configuration file. Probably in this example we don't use the I2C bus. How I can find an example to communicate with the I2C bus of the CS42L51 component. Thank you for your helps.
